Problemas p/ instalar cheats
Sympathy Devil
:help: Estou com dificuldades p/ instalar cheats em alguns jogos, tipo alguns pedem o seguinte:
A) Vampire: Bloodlines Cheat
Just start the game with -console added to the shortcut command line. Press tilde (~) to open the console in game, and use these cheats to do various things. Note that the console is very friendly, and if you're looking for a particular code just press a key like 'g', and all the commands that start with g will display. Press up and down on your arrows to scroll through those commands, and enter to activate the selected one.
:help: PERGUNTO: ALGUEM PODE ME EXPLICAR O QUE É ESSE "shortcut command line" E COMO EU FAÇO PARA FAZELO????
B) Max Payne 2
Change Character
Make a shortcut to maxpayne2.exe, right click on it and select ''Properties.'' Where it says ''Target:'' you will see the location of your maxpayne2.exe file. Change this text so that it reads ''C:\Program Files\Rockstar Games\Max Payne 2\MaxPayne2.exe'' -developerkeys.
Once in game, press PgUp and PgDown to change your character model. Some models are special, and some levels do not work properly with this code:......
:help: PERGUNTO: JÁ PROCUREI NAS PASTAS DO JOGO E NÃO ENCONTREI O ARQUIVO
"maxpayne2.exe". COMO EU FAÇO P/ ACHAR OU "CRIAR" ESSE ARQUIVO???
C) Neverwinter Nights Cheat Codes
Cheats
A única maneira de acessar os seguintes cheats é editar o arquivo Neverwinter Nights .INI. Antes de tudo, faça uma cópia do arquivo.
Localize o arquivo nwn.ini na pasta do game e abra-o através de um editor de texto. Sob a seção "Game Options", adicione a linha Debug Mode=1. Salve o arquivo .ini, e inicie o game. Durante o jogo, tecle “~” e digite DebugMode 1 para habilitar o modo de cheat. Tecle “~” novamente e aperte Tab para ver todos comandos debug. Tecle Tab para se movimentar pelos comandos.
PERGUNTO: JÁ FIZ ISSO TUDO CITADO AI EM CIMA E NÃO DEU CERTO, ALGUEM SABE O PORQUE DISSO???
aGRADECERIA MUITO SE ALGUEM ME DESCE UMA FORÇA!!!! :help:
