Controle remoto ppa com arduino funcionando
Pessoal, comprei um controle remoto da marca ECP, com chip HT6P20, e com o código abaixo funcionou bem no arduino, até com um bom alcance, com uma antena de 50cm no receptor. O que não estou conseguindo é comparar o código recebido para implementar as rotinas. A comparação em vermelho, no final,  é que não está funcionando:
Alguém pode ajudar?
TITLE: DECODER FOR HT6P20B ENCODER
CREATED BY: AFONSO CELSO TURCATO
DATE: 18/JUN/2014
E-MAIL: acturcato (at) gmail.com
LICENSE: GPL
REV.: 04
DESCRIPTION:
http://acturcato.wordpress.com/2014/01/04/decoder-for-ht6p20b-encod...
DESCRIÇÃO:
http://acturcato.wordpress.com/2013/12/20/decodificador-para-o-enco...
const byte pinRF = 2; // Pin where RF Module is connected. If necessary, change this for your project
int lambda; // on pulse clock width (if fosc = 2KHz than lambda = 500 us)
struct rfControl //Struct for RF Remote Controls
unsigned long addr; //ADDRESS CODE
boolean btn1; //BUTTON 1
boolean btn2; //BUTTON 2
boolean ACT_HT6P20B_RX(struct rfControl &_rfControl){
static boolean startbit; //checks if start bit was identified
static int counter; //received bits counter: 22 of Address + 2 of Data + 4 of EndCode (Anti-Code)
static unsigned long buffer; //buffer for received data storage
int dur0, dur1; // pulses durations (auxiliary)
if (!startbit)
{// Check the PILOT CODE until START BIT;
dur0 = pulseIn(pinRF, LOW); //Check how long DOUT was "0" (ZERO) (refers to PILOT CODE)
//If time at "0" is between 9200 us (23 cycles of 400us) and 13800 us (23 cycles of 600 us).
if((dur0 > 9200) && (dur0 < 13800) && !startbit)
//calculate wave length - lambda
lambda = dur0 / 23;
//Reset variables
dur0 = 0;
buffer = 0;
counter = 0;
startbit = true;
//If Start Bit is OK, then starts measure os how long the signal is level "1" and check is value is into acceptable range.
if (startbit && counter < 28)
++counter;
dur1 = pulseIn(pinRF, HIGH);
if((dur1 > 0.5 * lambda) && (dur1 < (1.5 * lambda))) //If pulse width at "1" is between "0.5 and 1.5 lambda", means that pulse is only one lambda, so the data é "1".
buffer = (buffer 1) + 1; // add "1" on data buffer
else if((dur1 > 1.5 * lambda) && (dur1 < (2.5 * lambda))) //If pulse width at "1" is between "1.5 and 2.5 lambda", means that pulse is two lambdas, so the data é "0".
buffer = (buffer 1); // add "0" on data buffer
else
//Reset the loop
startbit = false;
//Check if all 28 bits were received (22 of Address + 2 of Data + 4 of Anti-Code)
if (counter==28)
// Check if Anti-Code is OK (last 4 bits of buffer equal "0101")
if ((bitRead(buffer, 0) == 1) && (bitRead(buffer, 1) == 0) && (bitRead(buffer, 2) == 1) && (bitRead(buffer, 3) == 0))
counter = 0;
startbit = false;
//Get ADDRESS CODE from Buffer
_rfControl.addr = buffer >> 6;
//Get Buttons from Buffer
_rfControl.btn1 = bitRead(buffer,4);
_rfControl.btn2 = bitRead(buffer,5);
//Serial.print("Address: "); Serial.println(_rfControl.addr, HEX);
//Serial.print("Button1: "); Serial.println(_rfControl.btn1, BIN);
//Serial.print("Button2: "); Serial.println(_rfControl.btn2, BIN);
//Serial.println();
//If a valid data is received, return OK
return true;
else
//Reset the loop
startbit = false;
//If none valid data is received, return NULL and FALSE values
_rfControl.addr = NULL;
_rfControl.btn1 = NULL;
_rfControl.btn2 = NULL;
return false;
void setup(){
pinMode(pinRF, INPUT);
pinMode(13, OUTPUT);
Serial.begin(9600);
void loop(){
struct rfControl rfControl_1; //Set variable rfControl_1 as rfControl type
if(ACT_HT6P20B_RX(rfControl_1))
//If a valid data is received, print ADDRESS CODE and Buttons values
Serial.println(rfControl_1.addr, HEX);
Serial.println(rfControl_1.btn1, BIN);
Serial.println(rfControl_1.btn2, BIN);
if(rfControl_1.addr == '2FE699')        //esse é o código recebido na serial
Serial.println("código válido recebido");    //não está imprimindo esta mensagem
