Tela Azul Desligando PC/ Fechando algo.
LKinho
Pessoal a quase 3 semanas meu pc vem dando tela Tela Azul, sempre que eu fecho um jogo ou desligo/reinicio o pc depois de 5hrs+ ligado da a tela azul. Já teve dias de não acontecer nenhuma vez, mas geralmente, acontece 1~2x, acho que so teve um dia que chegou a acontecer 3x. Eu ja formatei o pc 2x desde que começou a acontecer o problema, da primeira vez ficou normal por 3 dias, e na segunda vez por 5 dias.
Usei o WhoCrashed e ele passou essas informações.
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 25/02/2014 21:01:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022514-12932-01.dmp
uptime: 10:59:47
This was probably caused by the following module: win32k.sys (win32k!HmgLockEx+0xA3)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF96000184283, 0xFFFFF88005054060, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\win32k.sys
product: Sistema operacional Microsoft® Windows®
company: Microsoft Corporation
description: Driver Win32 multiusuário
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
uptime: 10:59:47
On Mon 24/02/2014 20:48:45 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022414-13509-01.dmp
uptime: 00:21:51
This was probably caused by the following module: cdd.dll (cdd!DrvAssociateSharedSurface+0x7B)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002AA301E, 0xFFFFF880045FE0E0, 0x0)
file path: C:\Windows\system32\cdd.dll
product: Microsoft® Windows® Operating System
description: Canonical Display Driver
Teve msgs diferentes também, mas como formatei e fiz um limpeza de disco, apagou.
Configuração:
Sistema Win 7 x64 Ultimate
Processador Phenom ii x4 965
4gb ram ddr3
Placa de Video Saphire 7850
Fonte antec hcg 620 current gamer
Placa mãe Gigabyte GA-78LMT-S2P
HD 500gb Barracuda
HD 320gb Samsung
A temperatura ta normal
Obs: Não sei se isso tem alguma coisa a ver, mas depois que começou isso tentei instalar o Win 8.1, e não consegui, a tela sempre fica parada na logotipo do Win 8.1, achei que fosse problema do dvd, mas pedi pra um amigo gravar e mesmo assim não consigo instalar.Obrigado.
Olá, eu indicaria você a testar toda a parte de hardware do seu pc, principalmente a memória, usando o Hirens boot você consegue testar tudo...
Mais fazendo uma breve pesquisa sobre o erro, parece que tem alguma coisa a ver com o driver de vídeo mal instalado, tente instalar novamente.
http://msdn.microsoft.com/en-us/library/windows/hardware/ff558949(v=vs.85).aspx
Usei o MesmTest, chegou em 153% e não acusou nada. Já o driver, eu baixei e instalei nas 2 vezes que formatei, sem contar antes de formatar. Vou baixar esse programa que você indicou, depois digo o diagnostico.
@Usei o Hiren's boot v10.2, e não achou nenhum problema, so não consegui verifcar a placa de video.
Bom dia!
Já iniciou a máquina em modo de segurança e verificou se persistia?
Já testou, tirar sua Placa de vídeo e usar o PC sem ela pra ver se vai persistir o erro?
Caso continue, abra seu PC, retire o cooler, troque a pasta térmica, limpe as ventoinhas.
Poste o resultado.
Abraço.
  • 11 meses depois...
